What are you looking to accomplish?Has anyone replaced their rear coils with an aftermarket spring, like those sold at Etrailer or SD Truck Spings?
Were they noticeably stuffer, and did they change the ride height?
Less sag, when I hook up my travel trailer. (No, I don't want air bags.)What are you looking to accomplish?
Thanks for relaying your experiences here. I see where the 1211's are 2400# springs... a bit heavier-duty than what i was looking at (the 1210's).. but good information.I had the tuff truck 1211 on my 4th gen to help with sag when hauling my ATV in the bed. I called them before buying and they said not to do the variable because those only stiffen up after you see about two inches of sag (truck was also leveled). Stiffened the ride some, but not too bad. Only noticed it on really bouncy roads. I pulled them and hope to install them on my 5th gen. Tuff truck said they would fit, and I have the North Edition with the one inch lift. Biggest thing was when I had the stock springs reinstalled on the 4th gen, the truck felt like the back end was so wishy washy! I pulled over to make sure a wheel wasn't falling off! I was just not used to the stock ride anymore. Really liked them on my 4th gen. Waiting for Bilstein adjustables to come out and will add the Tuff Truck 1211 then. Fingers crossed they will fit.
Did you happen to replace the rear shocks at the same time? That might have contributed to the rougher ride. Do you remember if they lifted the truck at all? (I'm hoping not, as that's what they claim.)
Thank you again, yours is the only real-world experience I've encountered I'm looking at the TTC -1210's, which are 2250# springs. ... How heavy was your ATV? How much did the rear end drop when it was loaded?I had the tuff truck 1211 on my 4th gen to help with sag when hauling my ATV in the bed. I called them before buying and they said not to do the variable because those only stiffen up after you see about two inches of sag (truck was also leveled). Stiffened the ride some, but not too bad. Only noticed it on really bouncy roads. I pulled them and hope to install them on my 5th gen. Tuff truck said they would fit, and I have the North Edition with the one inch lift. Biggest thing was when I had the stock springs reinstalled on the 4th gen, the truck felt like the back end was so wishy washy! I pulled over to make sure a wheel wasn't falling off! I was just not used to the stock ride anymore. Really liked them on my 4th gen. Waiting for Bilstein adjustables to come out and will add the Tuff Truck 1211 then. Fingers crossed they will fit.
Not much sag with the 1211's, maybe an inch. With the stock spring, 2-3 inches. Road really nose high. And I don't like the Cali Lean lookThank you again, yours is the only real-world experience I've encountered I'm looking at the TTC -1210's, which are 2250# springs. ... How heavy was your ATV? How much did the rear end drop when it was loaded?
Thanks again... I did ask, and they verified that the 1210''s would fit.Sorry, my phone screwed up and I double replied. ATV is #725.
