Has anyone upgraded the 120vac system?
Frozenwater
Have a 20 sport, the ac outlets are pathetic for the power they provide...
Before I start trying to dig up the wiring, finding out where the inverter is, what the wire gauge can handle etc. I was curious if anyone's done it yet?
Also, I hate Ford, but the fact they put a plug in the bed appeals too me.
Thoughts anyone?
Thanks
Malodave
Rindge NH
The Inverter is located behind the Radio in the Center Stack.
I want to add a Second Battery in the Bed with a Pure Sine Wave Inverter
to run a Computer/TV or other things that need that type of output. I have
a Bed Cap on a 6'-4" Bed. I will also have a 72 Gallon Aux Fuel Tank in there as well.
Malodave
mikeru82
The Palouse
I'm just spit balling here, but if I needed more power I'd just add another inverter and keep it separate from the OEM system. I seriously doubt the existing wiring is rated for anything higher than what the system is rated for from the factory. So you'd have to strip out the existing wiring and inverter and replace it. You could mount the new inverter wherever you would like, run your own wiring to the bed, and install outlets wherever it's convenient for you.
Frozenwater
Ya, I'm thinking the same. May just look to mount another one somewhere.
