cipherbreak
- Jul 16, 2018
I had CDT speakers on my previous car and they were great. They are, however, more expensive than some of the mainstream offerings.
I got my 2nd pair of 2 ohm "CL-69SUB/CF.2 - CDT Audio 6X9" and installed after work. The overall system sounds good, and no Active Noise Cancellation issues. I did the same things I did with the back doors, but I put some "Uxcell a15011200ux0421 Black 5m 16.5ft Length Car Speaker Sealing Tape" I bought on Amazon for $6 that was perfect for sticking on the speaker mount hole before installing the speakers. I did run into a couple problems. The windows seem to be running into some binding going up (like half way up). The driver side goes through the normal motion and closes, but the passenger would strain a little, then go back down. I finally got it to go all away up by pushing the up button in quick bursts. I did pull the door panel again and pulled the door cable more out of the door frame. It went up after that, and thought everything was good, but it did it like the next time. This go around, I used a lot bigger pieces of the sound deadener, and I'm thinking there may be some clearance issues in some spots. I over-lapped with some of the OEM stuff already there, so I'll take a look again tomorrow (it was starting to get dark) and possible trim or remove some pieces. The 2nd issue was that the inner plastic door panel the speaker actually sits in is rattling real bad with the added base. I had to turn the base down a bit from my previous settings, and it sounds pretty good. I may have to put some sound deadening material on that inner panel, but figure it would be a pain trying to get the outer panel to fit back on the door.
I used a zip tie to snug the metra harness against the speaker, so I don't think that is it. I'm not seeing scuff marks on my tint (so it's likely not a speaker issue).Yeah I had to check my windows too before putting back together and tape the harnesses to the basket all they wouldn't hit the window.
In regards to the deadening material and railing. I was able to put a fair amount on it without problem. Try to really apply and mold it to the back side of the speaker mold. That seemed to help a fair amount.
Also, I thought I had rattling but it turned out to be the nuts for the door panel screws. Tightened them up.... Gone.
How did they sound? I also plan to replace the dash speakers as well as adding a center dash speaker as wellMy Kicker 43DSC69304 fit the front doors. 3-1/4" mount depth according to crutchfield (I didn't actually measure before I put them in).
I was told by many other threads that the 71-050 is the correct adapter to use even though it is only carried by Crutchfield, even the Metra site says they are still researching the adaptor for our Trucks at this time as of TODAY and it is definitely not the 72-6514, all sites Metra, Amazon and Crutchfield say to not use that one. So I went with the 71-050 from Crutchfield and will just try my lick that way. Ordered them yesterday.I ordered a pair of the CDT CL-69SUB/CF.2's. Will probably stick them in the rear, and if all goes smooth, order a second pair for the front. Crutchfield indicates a Metra 71-050 adapter is needed. After looking for them on e-bay, etc., I found another forum saying the Metra 72-6514 is the replacement adapter, but that the Polarity is reversed from the 71-050. For anyone who has installed the doors, and used the 72-6514, were you re-pinning them, cutting the connectors off and swapping polarity, installing as is, etc.
All are 4 ohm.Are the HK speakers 2 ohm or 4 ohm? this is a very important question that I feel most of us need answered that have that system in our trucks, for the system to run right for the specific ohm speakers we choose, please advice, I have a order on hold and am going with either 4 ohm or 2 ohm with the info provided
whats been your experience with these 6x9's so far? thanksMy Kicker 43DSC69304 fit the front doors. 3-1/4" mount depth according to crutchfield (I didn't actually measure before I put them in).
Thanks, I'm adding a JL audio 10" sub so I should be good. Question though, did you have do modify anything to fit these to the front doors? I ask because crutchfield says these only fit the back doors. Thanks again.I like them. I am by no means an audiophile, but I am happy with them. I will say I didn't get much bass out of them and subsequently put a sub in.
Have you pulled the trigger on the CDT Speaker swap?? Interested to see how it sounds. I believe I have settled on the CDT CL-69S.2, slim 2 ohm speakers for all 4 doors. I think that is the best option for fitment and closest match to 2 ohm factor speakers but a considerable upgrade. I talked to Ken at CDT yesterday and they put them in a 2019 Ram and said it sounds great with the factory head unit, only swapping speakers.cdt has a lot of options. https://cdtaudio.com/6x9/6x9_series.htm
i'm planning on going with something from them. just have to figure out if there's room for the CL-69 SUBCF to fit.
