Buz
- Sep 18, 2020
There are numerous threads on the 19 speaker HK system, and the consensus is that it's much too 'boomy'.
Those that are saying theirs sounds terrific either 1) have the bass slider on the EQ down into negative territory, 2) disconnected their subwoofer, or 3) they truly don't understand how to evaluate a balanced sound system.
The HK system is FAR from balanced. Balance among ALL frequencies is what makes a sound system 'good'. Balance between the high's and the low's and distinctly hearing individual instruments when the EQ is at or near flat settings.
To approach balance on the HK system, the first thing needed is to lower the bass EQ almost all the way down to -6 or so. Since there is only a 3 band EQ, this snuffs out many of the pleasant low and mid range frequencies. You're then left with some mids and as much highs as your ears can handle. Bass -6, Mid 0, Treble +3 is not how a balanced system looks on a three band EQ. A flat EQ with high's and low's slightly elevated is more in line with balanced. But the HK system sounds like crap with those settings.
Since it appears RAM isn't going to own up to this fail with the HK sound engineering, the best thing one can do to balance their system without having to spend money is to disconnect their sub. This did wonders for my truck, but I still feel cheated that I'm not getting the deeper frequencies I paid for.
