Quint
I've read a bunch of bed light threads, and watched many of the videos. Most show how they either tie into the OEM bedlight wiring or, if they get power from the 7-pin connector, they just show the location where they physically ground the circuit. My question is where in the circuit to run the ground.
My plan:
- Take power from the red constant power in the 7-pin trailer harness
- Install a 5amp inline fuse then run up to one of the wires on my light button
- Run power out of the 2nd wire in the button to a pig tail, which splits to run power to the strips on both sides of my truck bed
- The LED strips have two wires. One will take the 12v power from the pig tail, and the other is my question.
I am assuming that I run that second wire from the LED strips and ground it to the frame. Is that the correct way to do it in a 12v system? (I find wiring in a house to be so much more straight forward!)
My plan:
