Grocery interior solution?
doomtrader
Poland
I was wondering do you Guys have any good and tested solution for carrying groceries in the cabin of your trucks?
Of course I can put the shoppings on the floor or backseat, but that usually ends up with some of those rolling on the floor. Usually because there is so much space. Using the bed is also not everytime conviniet enough (I've got cargo bar with some nets).
So any cabin nets or things like that?
Something like this might help you out https://www.walmart.com/ip/Car-Trun...V-3-Section-Collapsible-Storage-Box/546021196
I personally fold one side of the backseat up and can usually fit one or two bags within the underseat storage flip out area. Holds it pretty well and the rest go on the ground in front of the seat no problem. I also have an AMP bed extender that when folded in holds the cargo fairly tight against the tailgate under the tonneau cover which also has worked pretty well for me although your cargo bar is probably similar.
I do this as well, plus utilize the RamBoxes when the weather is right.
I'm using this.
That looks like it will work better than the factory hooks!
I use this in the bed but it would work well for groceries too, and you can get smaller versions of this type of organizer that are very similar. Collapsible, lighweight, adjustable inside, all kinds of pockets on the outside and ends, handles if you need to move or carry it, good size but not too big, has adjustable straps on it if you want to hook it onto the floor cargo hooks, etc. Comes in black, blue, red, and even one with an insulated section for temperature preservation. (Third picture below shows what it looks like in the bed of my truck. Wasn't taking a picture of this item specifically but you can see it pretty good.)
Amazon link
tailgate-mat-jpg.48847
