Grill LEDs
Leif_Ram2019
Seattle, WA
Cool, that keeps it simple, less wiring, not having to figure out where to put a switch, etc.
Okay.. One more question.
Is this the configuration for the lights you used?
23700
Wakesnowb
I'm loving this. I don't think up-badging at all. I love that it's inexpensive and not-permanent and looks cool as hell.
One more question: Did you simply wire these to the accessory stud on the fuse box? Or did you wire an inline switch? And/or did you do a more proper install using a relay?
Thanks,
Leif
I am working on wiring my light bar that has DRL mode. Should I power the 3 way rocker switch to acc fuse or do a relay off of the marker lights? Any pros or cons to either method?
