Most people use the clutch block off plate. But in your situation (if you have factory aux switches), you don’t need to pass a wire into the cab. There is a gray connector under the steering column specifically for using aux outputs inside the cab. You would use the connector with the two big loops in your accessory bag. https://www.ramtrucks.com/BodyBuild...jGgHzAHGUTU0WB3rWuqSY7YmQ2vEhuBWBHJd9E9IrKxgWhat is the best way to get a wire from the up fitter plug back into the cab? My goal is to power a UHF radio with one of the aux switches. Truck is 2019 3500
awesome. thanks for the infoSo, in the example below, you run a jumper wire from #4 aux 2 connector at the aux PDC to whatever port of the switch you want to use. Switch 1 is being used in my example with the purple crayon-
Then, you plug that connector with the two loops of wire into the connector under the dash, and the purple/yellow wire on that connector will be the aux switch output for in the cab.
