Gen5 RAM subwoofer replacement - Pioneer shallow or harman kardon from laramie?
Tjw
Looking at adding an "economical" sub upgrade to my Alpine system. I would like to replace the factory sub with either the direct fit pioneer, or possibly get the factory harman kardon from the laramie. (Which i believe is better than the alpine sub)
any suggestions? I will stick with sub behind the rear seat.
sppb32
Factory subwoofer sucks, well it's ok for some people but if you like heavy bass you need to go aftermarket, the factory one on the Alpine system is also a 3 voice coil subwoofer, first one i ever seen
rgreener77
I’ve had a lot of aftermarket stereos in my time, I’m fact I used to install them. And , the Harmon Kardon is absolutely money. When I traded my 2020 for a 22 it was an upgrade I insisted on having. It’s an all around great sounding system
djevox
VP of Creative Thinking
MD
I did mine with a $20 line converter on the rear speaker outs Schosche line converter with bass knob and bought a used sub, amp, and sub box from a silverado and just chopped it in half and trimmed two edges to get the height correct. Total cost $190
Edit: I unwired the stock 10” TVC sub by removing the pins out of the pigtail at the alpine amp for reuse whenever I sell or trade the truck.
MarkKoz
Hello!!!
2020 RAM 1500, 8.4" , 6 speak., no factory amp and sub.
I'm installing a aftermarket amplifier. Where can I get the signal for the "Remote" of the amplifier? From which module or connector?
