Gas mileage
MoPartinez
Wanted to see what other guys with a similar setup are getting mileage wise. I'm getting 12.9 mpg around town with a 2021 Bighorn 5.7, 3:21 rear end, two wheel drive. It's got less than 60k miles on it.
Only modifications are taller LT tires (275/65/20) and a so-called "performance" muffler. Stock suspension. I driver pretty mellow but I get on it to pass people or get on freeway on ramps.
Haven't done too much highway driving to gauge it properly.
Also, had a 2016 Big Horn that had the identical drivetrain and modifications and it got 15-16 mpg around town and 18 highway.
Did you recalibrate for the tires? I have a 2020 BH 4WD with 3.92 gears and I get much better gas mileage. Around 15 to 16. I've hit 19 on long interstate drives. I'm on the stock size passenger tires.
34" tires seems to be your answer, I've never owned a truck with 33 or larger than didn't get 13 mpg or less.
However, you stated you had a 2016 with similar size tires? If so, I guess for you maybe it's in the axle ratios, or weight difference as the DT is heavier than the DS.
I'm getting 17.5 around "town"..... granted that's a rural town, but still some stop and go. On the long rural roads (basically 65 mph for 40 miles, slightly hilly), I have averaged 21 mpg. This is checking manually, a little less than showing on the dash (that's 18/23). I feel good.... that's running 295/65-20's(35") with a 3.21 rear end, 4x4. 5.7 e-torque.
