Gas mileage
MoPartinez
Wanted to see what other guys with a similar setup are getting mileage wise. I'm getting 12.9 mpg around town with a 2021 Bighorn 5.7, 3:21 rear end, two wheel drive. It's got less than 60k miles on it.
Only modifications are taller LT tires (275/65/20) and a so-called "performance" muffler. Stock suspension. I driver pretty mellow but I get on it to pass people or get on freeway on ramps.
Haven't done too much highway driving to gauge it properly.
Also, had a 2016 Big Horn that had the identical drivetrain and modifications and it got 15-16 mpg around town and 18 highway.
Did you recalibrate for the tires? I have a 2020 BH 4WD with 3.92 gears and I get much better gas mileage. Around 15 to 16. I've hit 19 on long interstate drives. I'm on the stock size passenger tires.
34" tires seems to be your answer, I've never owned a truck with 33 or larger than didn't get 13 mpg or less.
However, you stated you had a 2016 with similar size tires? If so, I guess for you maybe it's in the axle ratios, or weight difference as the DT is heavier than the DS.
15-16 around town, close to 19 on highway
2021 limited 5.7 3:21 stock tires
I'm getting 17.5 around "town"..... granted that's a rural town, but still some stop and go. On the long rural roads (basically 65 mph for 40 miles, slightly hilly), I have averaged 21 mpg. This is checking manually, a little less than showing on the dash (that's 18/23). I feel good.... that's running 295/65-20's(35") with a 3.21 rear end, 4x4. 5.7 e-torque.
I have a 2022 Bighorn 5.7 (no E Torque) upgraded Waldoch package, 6" lift, 35x12.50r20 custom wheels and performance exhaust and I'm getting 14-15 around town and 17-18 highway.
I was getting 20mpg stock (5.7, 3.92 posi), but always trying for more, then Wifey-pooh said "turn that guage off"..now I enjoy my truck SO much more😁
24 Hemi in a Laramie, computer says my avg mpg over 18,000 mi is 21.1. Its my 3rd hemi and the mpg surprised me. Pretty good for a 5,000 pound 4wd truck. I know some say a hand calc is often 1mpg or so lower, but even still.
same truck 2wd 2019 laramie crew 5.7 NON-ET stock tires around town 18-19 hwy 23-24
if i get down on it and it it will drop mpg's fast
I have a 2022 Longhorn 5.7 eTorque with 3.92. I have tracked every fillup since I bought the truck with the Fuelly App. My worst mileage from a tank of gas is 14.4 and my best is 20.8 my lifetime average is 17.4 over 62,825miles. I do not drive a lot of stop and go traffic. Highway mileage is 18-19.5
Mind if I ask what your cruising speeds are and how flat or hilly are your drives, typically?
Another trip from Arizona to Texas and back. Averaged around 17. Texas has 85 mph speed limits on some freeways. At a constant 85 I was getting 14. Of course most everyone else is doing 90 so it's even less at that speed. Now, for my neighbor that tells me he gets mid 20s with his Raptor.....I got 27😆
We recently bought a 2019 tradesman with ORG & tow package with 3.92, 5.7 e torq, 31k miles, and have been averaging 20/21. We put new tires, the OEM size Falken AT3W. We have been pleasantly surprised by the MPG.
I get 16mpg to 17mpg mixture of highway and city driving. I have a 2025 Laramie with 3.0 inline six.
2024 Limited, Hemi, 5" lift with 35x12.50 r22. Last tank, 14.5 and that included more highway miles than I usually run. This take, 12.8
2019 Limited 4x4 about 65k miles, 22 inch rims all around w/stock size tires. About 12mpg around town, not much better on the hwy.
