Hi,
I have a new 2022 Ram 1500 Limited. Not one, but all four doors have horrible varying gaps. It just gets worse from there. The hood is way off, and the front bumper is lower on right side, and over to the right by 1/4 inch. The gaps on this truck range between 2mm to 8mm in some places. Passenger doors don't even line up with each other. Tail gate is out on the bottom and in on top. Took it to two dealers, and both body shops they sent me to said it had too many conflicting gap issues to be fixed. I do have a case open with FCA. They have been dragging this out for 8 months saying one thing after another then changing back to a different awnser. They originily said they would replace it, then changed to a a$7,000 trade in credit. The local dealer says they don't even want it since it's so bad they would have to wholesale it. They did call and tell FCA case Mgr. this while I listened to call. Still no help from FCA. If anyone else is having these isssues and has an idea, or resolution would appreciate any help.
Thank you
Thank you
