G/T owners - looking for guide on bed box side decal placement with rambox
PdPuNOme
5thGenRams Supporter
Jersey
Looking for a 22+ G/T owner here that would be willing to provide a measurement template guide to assist in properly placing the factory G/T decals on the rear bedsides. I am specifically looking for a rambox version, but both versions with and without would be helpful to the community as a whole as well.
Doesn't matter if you have a Laramie G/T or Rebel G/T variant, all would be the same.
OEM Mopar part numbers for the two sides and two-color variants (oem is different than aftermarket ones out there, learned that, go oem imo)
Note: Only one p# for each color as same for either left or right.
Black left and or right side: 68529637AA
Gray left and or right side: 68529638AA
ChatGPT says:
Measurements for 22+ Ram 1500 G/T (RamBox)
RamBox trucks have a slightly lower available surface because of the lid seam.
Vertical position:
1.75" – 2.0" (≈44–51 mm) below the bedside crease
(the decal moves up slightly so it doesn’t touch the RamBox lid gap).
Horizontal position:
Same as non-RamBox: 7.0" – 7.5" from the cab seam.
Note: Some owners push to 8" depending on decal size to avoid lid curvature.
ChatGPT says:
Vertical position:
Thanks, but not accurate and not for the g/t decal, cannot trust ai for everything. Need someone to actually measure theirs.
These pics are Driver's/Left side on 2024 Laramie G/T with Ramboxes.
(1) Front edge of box (near cab) to edge of "G" is 43.5"
(2) Horizontal body line/crease behind wheel well to bottom of "T" is 13.625"
(3) Tailgate light edge to point of "T" is 3.625" (tough to measure, but going straight across top of "T" and measured at the very point of the "T")
(4) Bottom edge of the Rambox to the top of the "G" is 1.0625" and to the top of the "Slash" between "G"/"T" is 0.75"
ALL these measurements are to the beginning of the CLEAR tape edge around the G/T letters..add 0.0625" (1/16") to these measurements if measuring to the actual colored letter. The clear border is 1/16" all around the G/T letters.
Sorry, tough to see where end of tape measure is starting in these pics..best I could do without a seamstress tape measure.
