OC.13
Anyone running the Fuel Rebel 18x9 with the +1 offset? I am wondering if I have to go with more negative offset to clear brake calipers? Don't want to jump up to a 20, as I like a little more side wall. Any help is appreciated.
If the wheels take 1/2oz weights you'll have to grind the edge of calipers down like 1/8" if they take 1/4oz weights you should be good. Basically it all depends on the thickness of the weights they use.Anyone running the Fuel Rebel 18x9 with the +1 offset? I am wondering if I have to go with more negative offset to clear brake calipers? Don't want to jump up to a 20, as I like a little more side wall. Any help is appreciated.
How’s the +1 offset look? Flush with fender? Little poke? I’m looking to do the same with my stock tiresAnyone running the Fuel Rebel 18x9 with the +1 offset? I am wondering if I have to go with more negative offset to clear brake calipers? Don't want to jump up to a 20, as I like a little more side wall. Any help is appreciated.
