Long story short, just got a call from the dealer that the fuel pump failed on my 2019 1500 5.7 with 40,200 miles on it. Has anyone experienced this? It was purchased CPO and they told me earlier that I am still under a 60k mile powertrain warranty. Now they're telling me it's not covered and will cost $1,470. Would that really not be covered under warranty?
The other day, the truck would sputter out a second later after cranking/starting like normal. If I gave it some gas for about 15 seconds, it would stay running. I then noticed it seemed down on power and was getting much worse fuel mileage which led me to believe it was a spark plug, injector, fuel pump, etc. issue. However, at the same time it also developed a significant transmission bucking where above 1500 RPM it would feel like it was wheel hopping. It was intermittent at first but today was constant and does it to the back wheels in 2WD and clearly does it to the fronts as well in 4WD. There was no CEL until this morning when I started it to take it to the dealer close by and when I got there and shut it off, it wouldn't restart and it was clear the fuel pump had finally fully gone. The bucking was so harsh that I really didn't think at the time it was an ignition or fuel issue and was transmission related, but I'm no expert. Could the bucking be caused by a bad fuel pump and would that really not be covered under warranty at this point?
