When I was truck shopping, I ran some numbers on fuel economy, just for fun (I only put 6-8K miles on my truck per year). I've updated them below based on the new eTorque numbers and 2019 GMC rating:
Contestants
2018 Ford F-150
3.5L V6 EcoBoost engine (375 HP, 470 lb-ft, 17/23/19 mpg): "Your vehicle is designed to run on regular fuel with an octane rating of 87 or higher.
For best overall performance, premium fuel with an octane rating of 91 or higher is recommended."
2019 Ram 1500
5.7L V8 Hemi eTorque engine (395 HP, 410 lb-ft, 17/22/19 mpg): "
89 Octane Recommended - 87 Octane Acceptable, 0-15% Ethanol (Do not use E-85)."
2019 GMC Sierra 1500
6.2L V8 engine (420 HP, 460 lb-ft, 16/20/17 mpg): "
Use premium 93 octane unleaded gasoline in your vehicle. Unleaded gasoline with an octane rating as low as 87 may be used, but it will reduce performance and fuel economy."
2003 GMC Sierra 1500HD (just for fun)
6.0L V8 engine (OE rated at 300 HP, 360 lb-ft, 10/11/10 mpg): Truck is tuned for 89+ and typically run
93 octane, with real-world economy of 11-12 city / 12-14 highway.
Results
Disclaimer: At just 7,500 miles/year, I'm not worried about fuel economy. So the differences shown below are minimal (using combined efficiency ratings). But let's compare anyway!
- First, my existing truck (2003 GMC Sierra 1500HD) easily consumes the most gas. At an average of roughly 12 mpg, I'm using 625 gallons per year. At $2.99/gal (93 octane), this translates to an annual fuel cost of $1,869. This sets our baseline.
- The new 2019 GMC Sierra consumes 441 gallons/year in the same scenario, saving me 184 gallons ($550). That's a good start.
- The 2018 Ford F-150 and 2019 Ram 1500 both consume 395 gallons/year, saving me an additional 46 gallons ($138) over the GMC. Better.
The math gets a bit more sophisticated if you consider recommended octane levels:
- The 2019 Ram 1500 finishes first overall, with annual fuel consumption costing $1,082/year at 89 octane (19 mpg, $2.74/gal).
- The 2018 Ford F-150 takes second, at $1,180/year, despite the same combined economy rating as the Ram, at 91 octane (19 mpg, $2.99/gal).
- The 2019 GMC Sierra (6.2L) finishes third, at $1,319/year, as this engine recommends 93 octane and consumes more fuel (17 mpg, $2.99/gal).
For me, there's little difference (less than $250) in annual fuel costs between these trucks. All of them save money over my current truck. But I'm not, for example, expecting to recover the cost of the eTorque option from fuel savings (even though it will do so in 5.3 years, per the post by
@cjgerson above but using $2.99/gal). More importantly, these numbers might be extrapolated to show a more significant cost savings for those of you that put 20-30K/year or more on your trucks.
