Turn Signal (Left) | White/Green (LF); White/Dk. Green (LR) | + | BCM above driver kick, white 24 pin plug (D), pin 14 (LF); black 48 pin plug (E), pin 3 (LR) |
Turn Signal (Right) | White/Tan (RF); White/Yellow (RR) | + | BCM above driver kick, black 24 pin plug (A), pin 13 (RF); white 48 pin plug (F), pin 42 (RR) |
Thank you! Just what I was looking for
Turn Signal (Left) White/Green (LF); White/Dk. Green (LR) + BCM above driver kick, white 24 pin plug (D), pin 14 (LF); black 48 pin plug (E), pin 3 (LR) Turn Signal (Right) White/Tan (RF); White/Yellow (RR) + BCM above driver kick, black 24 pin plug (A), pin 13 (RF); white 48 pin plug (F), pin 42 (RR)
I don’t have that listed in the documents I have, but I think the wire for those lights only goes from the light to the door module inside of the door. Shouldn’t be to hard to trace it.Skyhawk42,
Can you please tell me where to tap into the white led lights under the door mirrors that fade on and then off to illuminate when the door is opened at night?
I'm still following and trying to figure it out too. I started on the led grille lights on my 2021 1500 bighorn. I was able to tap into the fuse box under the hood for the led running lights. I used the fuse for the "trailer cam." But no matter where I try to tap into to get the power for sequential turn signal, it doesn't work. I actually had it working a couple of times while the truck was turned off and in the "run" position. But once I started the truck, they didn't work properly.Hi Folks, where are these wires located ? I want to install hood LED light strip with turn signal functionality but not sure where to tap into for the turn signal wires ?
Subscribe to alldatadiy and you get your model year specific schematics and description of operations of all the systems.Also looking for info to install a led strip with turn signal function. Why is this so difficult? I can’t even find the wiring to the headlights.
