Front sway bar on 2023
Spanish Cobra
Houston, TX.
Does the 2023 Rebel have a front sway bar ? Display says it's disconnected. Truck is still new to me and just looking/playing with different settings. Heck if anyone in the Houston area is knowledgeable and wants to educate me, I'd be willing to take lessons.
raygun9
Look at the oil pan drain bolt, the sway bar is right under it (at least on the 2020)
Sent from my SM-G781U1 using Tapatalk
All trucks have a front and rear sway bar. It's required by federal safety standards
Dewey
WI
I noticed on my OR pages it says “Disconnected” as well and was wondering why that is? The bar is clearly bolted on and connected.🤔
cskindt
SW IA
My lowly big horn is the same in that display. We don't have any sensors or actuators to detect the position and disconnect/reconnect the sway bar.
Just ignore it and check your sway bar linkage bolts before and after you drive your truck.
Because you don't have the sensor to tell BCM if it is connected or not. That's only on the Power Wagons.
boogielander
hmm never noticed it.
will take a look at it when i finally drive it this weekend
