Check out the Hidden bumper light from Rough Country.the picture just shows the daytime running light onBest location for light on roof or in grill... and any good brand recommendations are welcomed and I am open for any size..thanks in Davy!!!
I am loving the rigid lights... is it the E2 series? Flood light in the back mounted by receiver hitch is what I am also looking at getting.If you want a good brand name go with Rigid, Vision X. I would stay away from anything on ebay or amazon. Also try to get one that has cree led's. I would go grille or front bumper, the one's on the roofs create a lot of wind noise.
I have a small 10 inch Rigid on mine mounted on my front licence plate and it out performs my buddy's 40 inch double row cheap amazon brand.
Post #26 shows my light and mount.
My 2019 Rebel
Just got my steps put on and added the beaver step. I notice you now have a Rebel in that new shade of white :LOL:. How are you liking those go rhino side steps? I'm torn between them and a nice set of nerf steps!5thgenrams.com
Have them do both mine come on in reverse and also with my switch if you get the curt adapter just tie into the reverse wire hot and ground and your good to go.Found a local dealer who has Cree aux lights who will install reverse lights for 200$ installed with switch or tied into reverse wiring.... which one is better option?
I was going to do that and the installer told me it would back feed into harness when you used the switch so I didn’t try it. No proof, just going by what he told meHave them do both mine come on in reverse and also with my switch if you get the curt adapter just tie into the reverse wire hot and ground and your good to go.
CURT 56584 Replacement Vehicle-Side Custom USCAR 5-Pin Trailer Wiring Harness https://www.amazon.com/dp/B007EA6WQU/ref=cm_sw_r_cp_apa_i_FkjRDb559ZSH8
What did they mean feed back to the harness?I was going to do that and the installer told me it would back feed into harness when you used the switch so I didn’t try it. No proof, just going by what he told me
