Supercraig1
- Feb 21, 2021
I've been having an ongoing issue with a clunking rattle in the front left section of my truck's suspension. I've had it into 1 dealer that replaced the swaybar and endlinks. This did not fix the problem.
I've had it into an independent shop that has said the lower front left ball joint is failing but they did not want to work with my extended warranty.
I brought it to a 3rd independent shop that said they didn't think it was the ball joint and said they lubed the slide pins on my front left brake caliper. This did not fix the problem.
The truck is only 3 years old (Rebel with 25k miles). It should be able to be fixed.
Ugh
Ugh
