WildWildWest
A recent noise has came about and it was found that the front driveshaft is rubbing on a plastic guard for a cable.
Trouble is, I don’t see how or why this has suddenly become a problem. I did just lift the truck 6 inches, however, I don’t see how this would have changed anything to put the driveshaft closer to this guard.
Looking for ideas on a fix? Is it safe to trim this guard out of the way? It is bendable, but does not stay. Maybe apply heat and bend?
Then again, if the lift did not cause this to happen, what did and maybe there is a deeper issue?
Is there any concerns with the driveshaft being scratched up? How easy is it for the scratches to cause the shaft to get out of balance and would this cause vibrations even though the shaft isn’t actually engaged?
I plan to goto a dealer and get under a truck to see if it compares, or if anyone is bored and would like to see if theirs is the same it would be greatly appreciated!
