From the manual
Derlant1983
Dearborn
Rear Axle (3.92)
We recommend you use Mopar Synthetic Gear Lubricant SAE 75W-140 (MS-8985). Limited-Slip Rear Axles require the addition of 5 oz. (148 ml) Mopar Limited Slip Additive (MS-10111).
Max Tow Rear Axle (3.92)
We Recommend You Use Dana SAE 80W90 Axle Lubricant.
Anyone know how to tell which 3.92 I might have? I’ve never seen the max tow option on a ram just ford.
Thanks in advance.
devildodge
Moderator
Central Pennsylvania
Max tow is the Dana Super 60 rear end. Only available in 2wd.
No one has showed up yet who has the Dana Super 60.
You have a 4x4. You do not have it.
Yours would be the top one. Requiring the Mopar oil
Derlant1983
Dearborn
Thanks, that’s what I thought I had but never seen any mention of a max tow rear before looking at the manual.
devildodge
Moderator
That number that everyone thinks their truck can tow...the one all the commercials for all brands like to show that is not available with the truck in the commercial.
That would be a Quad cab 2wd Hemi with eTorque and the Dana Super 60 rear axle.
No one has showed up with it yet. I really just want to know someone got it.
Dusty1948
Rochester, New York
Rear Axle (3.92)
Thanks in advance.
The 9.5 inch Dana Super 60 differential is easy to recognize on a Ram 1500 as there are cooling lines from the engine going to it.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 044959 miles.
