GlobetrotterV8
- Jun 28, 2025
Hi, I am the owner of a 2019 RAM 1500 Sport with 5.7 V8 Hemi. After I bought it new I had it lifted 5", put 35" wheels on 20x10 rims and had my ECU altered so the 4 Cylinders don't shut off anymore, changed the throttle response and took out the Limited Max speed. The Max speed is now 140mph but doing that on the 35" tires is a bit tricky. I cut out the giant oem mufler and installed a outlaw mufler from Flowmaster. Currently it has 52000 miles and I had some issues with the truck. I had the windshield tinted and that damaged the BCM. Regularly the dash showed me there was no BUS working in the car. I can tell you doing 85 mph in heavy traffic in the rain and than losing wipers, indicators and blower is no fun. In many occasions I couldn't even switch the car off or lock it. Now I bought a second hand BCM on ebay from a 2021 RAM 1500 and still waiting for delivery. I want to program the "new" second hand BCM with an OBD dongle using the Alpha OBD scan app. I also got the splittercable with the 8 pin and 12 pin plugs but I can't seem to locate where to attach them under the dash. Did anyone use these? Also the pushbutton for ACC and Start doesn't work so i guess the old BCM is fried or a fuse or relais died on me. Anybody has experienced this too? I need to copy the data off the sitting BCM and past it to the "new" one.
Worst case, I have to crack the housing of the BCM and see if there's any visible damage on the mainboard and replace some electronic components to get it working again.
