Probably a good idea.yeap. bound to happen.
im planning to do PPF to minimize the pinstripes and possible damages
I had two clucks with parts you've mentioned.plan to wrap the truck. cause or pin stripes lol…… but for suspensions idk whst esle it needs … have new rear control arms by core 4x4…. dobinson hd springs … fox suspension
changed to maxx suspension for front sway bar…. cnt find the clunk sound for **** …
dam sounds like everything i had some issues with lol …. i guess when i get home i have some parts to play withI had two clucks with parts you've mentioned.
My front maxx links kept loosening up at the sway bar side even when torqued to spec. Blue loctite and they've been good 1000 miles or so.
I had an annoying clunk I couldn't find in the rear. It was my core 4x4 sway bar links. Torqed to spec and wasn't enough apprantly. Had to go overboard and it stopped it. I've also heard about their rear control arms needing a good 200 ft/lb to get them settled. Well above the 130 or so I've seen elsewhere.
Dobson uses single rate springs, right? I got a little clang out of my Clayton springs before isolators were installed as well. Maybe worth a look?
seems pretty solid plan! good luck with the clunk lolplan to wrap the truck. cause or pin stripes lol…… but for suspensions idk whst esle it needs … have new rear control arms by core 4x4…. dobinson hd springs … fox suspension
I'm considering going with a 4" lift on my rebel instead of the 3" (especially since I would only be setting it at 2.5"). I'm looking for a little more height than that. If you went with the 4" lift, how would you have done it?hahaha well to be fair this weekend going in to and out of toquerville falls was the first time I wish i got more lift lol
scraped slider and exhaust tip because not enough ground clearance.
custom king shocks.I'm considering going with a 4" lift on my rebel instead of the 3" (especially since I would only be setting it at 2.5"). I'm looking for a little more height than that. If you went with the 4" lift, how would you have done it?
