RamFan70
I recently swapped out the factory footwell bulbs to Lasfit 194 LED T10's and started getting the rear drivers side door ajar light staying on. Doors won't lock, no remote start, and all the other things tied into a door thinking its open. So I concluded the only thing I had done recently was the bulb swap. Sure enough pulled the T10 LEDS and everything back to normal. Is there a specific LED bulb I should be using for this? Any input on what this little bulb could be doing to cause this? If its a canbus error can I modify it through AlfaOBD? Any help and input would be much appreciated.
Cheers!
These are the bulbs I used.......
Cheers!
