Fog lights not working (no indicator either)
pullejo
Hey gang - my fog lights aren't working... the button does nothing whether or not my lights are on/off etc and the indicator doesn't light up either.
I searched on here to see if anyone else has run into this problem and couldn't find anything.
I checked the fuse box diagram and don't see a "fog light" fuse - maybe exterior lights?
Also - this started happening after our battery was run down completely and we had to get a jump... the electrical system on this truck has really been my only complaint.
Try unhooking the battery for a few seconds, then reconnecting it to hard reset the computers.
pullejo
Haven't come back and it's been two days. Dang.
pullejo
check fuse.
Checked exterior fuse box (f25 is what I would think would have blown).... I'm wondering if perhaps its a fuse in the interior box (which is a total pain in the a$$ to pull fuses from) that runs from the switch. Maybe f06 or f36?
boogielander
could be. i don't have my truck with me on weekdays but usually when we have electrical gremlins at the shop we check fuse box first before diving into something more complex.
evskie53
If you have your brights on the fogs will not activate and the indicator will also not turn on. Worth double checking.
pullejo
Well... I just got my oil changed (Palmer RAM/Jeep in Roswell GA - where I bought the truck) and asked them to diagnose this issue...no fog lights, headlights won't turn off... etc. They checked my fuses like I did... all good. They said I'd need to schedule a follow up to have the electrical diagnosed....in Jan.
I got home and figured I'd spend a minute doing more research.
Turns out the backplate on the headlight switch tends to fall off on our trucks, making it not work. Yep.
I took my plastic panel tools, popped off the switch panel and sure enough, the backplate on my switch had popped off. There was also two pieces of tape on it as if this had happened before.
All lights and switches work properly now.
Here's the video I found.
Darksteel165
Massachusetts
I was wondering if it was something like that since you weren't getting the indicator on the dash.
Gota love cheap fixes.
kapinallinen2
5thGenRams Supporter
Southern Maryland.
That happened to my coworker, he had hit the switch with his knee getting into the truck.
