Fog light recommendation
Tlaug01
Hey guys. I had a halogen big horn that I upgraded the headlights to the oem mid level led headlights. Looking for thoughts on what fog light would come closest to matching the color temperature of the headlights. Looking at the morimoto xb, but have read some bad reviews.
I am I big fan of the xenon led pro kits they use heat find instead if fans so they have a less chance of failure that's what I have in my low and high beam but with that said I am running the deAuto leds in my fogs they are a dual beam that are white and yellow so when you want white you got it and yellow when you want it check them out.
I used SLF LED Fog Light Bulbs, easy plug and play and the color is very similar, no error codes
I have the Morimotos XBs. The color matches perfect, but they do flicker slightly. It’s almost undetectable but it is present. I just live with it because it’s only noticeable when I look at the light cast onto a white wall or garage door, etc. it’s not noticeable when looking directly at the lights themselves. Others on this forum have had no such issues.
Otherwise, they work fine. I’ve had them for around 6 or 7 months now with no other issues.
