Good Afternoon All,
My 2019 is now at fluid service intervals, or a little past and needing to do a full fluids swap. Truck has 110k on it (lots of highway for work) so looking to start service. Truck is a 2019 Ram 1500 (new body style) with the Hemi (not etorque), 8HP75 transmission, and 3.21 limited slip rear). I am looking for recommendations for fluids specifically.
For the transmission I have a PPE HD pan that I am planning to swap to (for the easier fill/drain and filter swaps) and then was considering Amsoil Signature ATF Fluid to replace the factory fluid. I see conflicting reports that the Amsoil fluid is better than OEM, or that the ZF or Mopar is best, or that Redline is best. I'm not worried about spending a little more for a better fluid, just want the best fluid for the application.
For the front differential, I am looking at the Redline 75W85 GL5, or Amsoil 75W90. Thinking the redline is the better way to go?
For the rear differential, I am looking at the Amsoil 75W90 Gear Oil with a 4oz additive of Mopar MS-10111.
For the transfer case, I am looking at Ravenol BW44? Not sure the best fluid here or the capacity needed.
Looking for any advice on fluids to get for all above or at least confirmation that these are safe routes to go.
Thanks!
Thanks!
