Are you refereeing to the ambient LED lighting?Hey guys!
I’m looking to swap my interior floor lights to red, anyone know how and what bulb is required? Thanks!!!
Thanks. You'd think it be as simple as swapping LEDs then, since you should be able to change them out if they burn. Pls let us know what you find.Yes sir
I'm Looking to change all ambient lighting to a different color, Something tells me the ones around the instrument cluster would be a PITA.
It would be awesome to have all the lights match red blue green or even the true white not the dingy yellow they are factorySomething has a loud mouth because I'm hearing it too...
Yep. Most new vehicles that come with ambient lighting now have this. Heck, I had it in my 2014 MB. Could chose green, blue, white, and red. The newer ones has infinite color adjustments. Guess they gotta leave some improvement for the 2020s... LOLIt would be awesome to have all the lights match red blue green or even the true white not the dingy yellow they are factory
Thanks for the tip, I was looking at it today and visually everything says pop it off from the top.I've taken the doors apart already. FYI.......that cover by the door handle is a mo fo to get off. Pop it off at the bottom with a 90 degree pick and slide it down as there is a tab at the top.
