Fix for those front bumper holes- cheap!
STR
... unless you feel that it doesn’t need fixed, or have a front plate. I used the nylon hole plugs pictured below on other vehicles in the past w/good results. Unlike the plastic push pins, the heads on these are only fractionally larger than the hole itself for a minimalist appearance. The plugs have a texture matte black finishes, so they match the Rebel’s bumper w/the black appearance package perfectly. You can barely see them from a few feet away. I suppose you could also paint to match other bumper colors. If bored, I might fill those holes in the side of the bed next :p. Note: I also used a small amount clear caulking, although probably not necessary (Size: 3/8” & available at Lowe’s for $1.06 for a pack of 2):
