First time purchasing after market wheels question
dano257
New Jersey
Looking to upgrade the wheels on my 2019 Big Horn Crew Cab 4x4 stock suspension and no ORG. I found this information about my stock 20" chrome wheels;
Style: 6 Spoke
Finish: Chrome Clad
Lugs: 6
Bolt Pattern: 5.5 Inch
Offset: 19.05mm
Is this info correct?
The tire size is 275/55/20
I would like to go to an All-Terrain type tire for the look. I don't go off-road much, although Jersey gets snow/ice in the winter.
I am looking at the Toyo A/T 3's or something similar and would like to get them a little wider and a little taller maybe a 285/60/20
Because I would like to go a bit wider, should the offset on the new wheels be greater than 19 or less than 19 in an attempt to avoid rubbing???
What offset would you guys recommend? New to the after marker wheel world. The truck has a lot of chrome on it and I would like to get some black wheels to break it up a bit.
Thanks for any insight/advice.
