Drove the truck to the Appalachian Trail, about a 15 minute drive. Walked for an hour and came back. Started the truck, let the Uconnect stabilize, set the temperature to low, then back up to 62. The horn blows once, the emergency flashers come on and the center console display switches from MPH to Tire Pressure. I tried manually turning on and off the flashers with no effect. Maybe ten seconds later the flashers turn themselves off and everything returns to normal after that. I manually reset the console.
4,400 miles, the first Gremlin. It seems like it could have been a low voltage condition but I didn't check the voltage until after everything returned to normal. It seemed like the AC compressor kicked on when I set the temp to low and that triggered a gremlin.
