are you going to get 35s ?I was finally able to install my lift the other day. Took about 5 hours in total including unbolting my helper air bags and adding spacers. Still haven't decided on which wheels and tires I want, so for now she will be riding on the stocks until I can make up my mind. View attachment 20717 View attachment 20718 View attachment 20719
I might stay at 34s because I tow and I have towed with a lot of different set ups in the past and I know going just one size bigger can really affect how it pulls.are you going to get 35s ?
I personally like the 295/65 better just for the look.Yep, like you said 295/60r20 is usually a good choice for this vs a 35. They typically weigh quite a bit less without giving up too much appearance
Isn't that back to a 35" tire though?I personally like the 295/65 better just for the look.
yes just a little narrower .Isn't that back to a 35" tire though?
So what are your initial thoughts on the Readylift kit?I was finally able to install my lift the other day. Took about 5 hours in total including unbolting my helper air bags and adding spacers. Still haven't decided on which wheels and tires I want, so for now she will be riding on the stocks until I can make up my mind. View attachment 20717 View attachment 20718 View attachment 20719
I love it! Rides the exact same and still tows fantastic.So what are your initial thoughts on the Readylift kit?
Any chance you could post some pins of ur front suspension angles? I'm so close to pulling the trigger on this kitI love it! Rides the exact same and still tows fantastic.
Thanks!!!!!
To be honest with you I dont remember. I pulled the measurements but never wrote them down. @Livinfast85, looks great!
What's the final delta on the front and rear? 3.5" & 1.5"?
