External fuse F17 for air suspension… but no air suspension… what is it used for?
Thatjusthappened82
I was checking fuses for mods using the guide by @HAL9001 and I stumbled across a 20 amp Micro2 fuse F17 for air suspension. I don’t have an air suspension, but wondering what it’s for and if it’s something I should stay away from with a fuse a tap… thanks!
kapinallinen2
5thGenRams Supporter
Southern Maryland.
F 17 along with F 22 is one of the two fuses that power the air suspension control module.
Do you actually have a physical fuse located in that spot?
Thatjusthappened82
Yes I have physical fuses in both F17 and F22… and I get 12v on F17 when the engine is running and I definitely do not have an air suspension.
