Extended Travel CV Shaft
I have a '21 with 2.5 Bilstein 6112s up in the front. The passenger CV axle has gone out and wondering if i should have it replaced at the dealership with the OEM CV axle or go for the Trakmotive extended travel CV? Any thoughts? I do quite a bit of offroading.
Have had the front completely stock other than the Bilsteins and Icon UCAs for 60k miles and this is the first issue i have had.
Get the Trakmotive. But if you are under warranty, and the dealer will replace it, I highly recommend letting the dealer replace it with OEM before putting the Trakmotive on. There is a high chance the xcaxle won't come out easy and they may have to ake diff apart. Once they replace it, under warranty, then install the Trakmotive ones, and it will be a much easier job for you. I was able to replace mine in under an hour
how often do you go full droop? catch air?
tbh 60k miles on the setup is quite good already, i'd go with stock CV unless you're catching air or full drooping a lot. i mean if the stock length is not good for your application yours wouldn't last 60k lol
The Trakmotive axles are almost half the price of OEM Mopar axles. Might as well save money and get a better axle
oh **** i didn't know that.
i mean i will when my cv eventually fail then i'll look into it and compare pricing with the mopar discount i get but that's good to know!
Just as an FYI, I installed one on my drivers side last year on my 2020, and had a very slight interference with my Fox 2.5s in a small spot. I drove it for around 50 miles to wear it down, and it's been perfect since
Hey mate, do you remember where there was some interference with the fox 2.5s? i am about to buy the same cv's as you.
Thanks
Sorry about the lack or replies. I just took these pictures, this is after about 30k miles on both. I did not modifications, just let the metals fight it out. This is the first time I've looked at it in over a year, and have done some pretty severe work/play with it then. I plan on having them rebuilt soon, as I'm at about 40k miles on them and just added 220lbs to the front end as well.
How the ride ? Any issues or vibrations?
