Exhaust tips
Medgas24
Has anyone else had the issue or noticed the exhaust tips move on their own and try to clamp it down more and same issue ?
I had that issue with the stock tips on my 2017 Rebel. Didn't matter how much I tightened the right tip, it would eventually droop some. I finally ended up cutting a small piece of sheet metal to use as a shim. It held position after that. So far I haven't had that problem with my 2020 Laramie or 2020 Limited.
