Thanks, that’s generally what I’ve been hearing. The time has come to purchase some hardware... need to improve the sound and level the rake. CheersIf you don’t mess with the cats you won’t void any warranty with a simple exhaust mod. Same for the suspension if you do a 2”/4”. Once you go big, the answer is, it depends. If they can tie a malfunction to your mod, they might give you a hard time. For example, a transmission issue or water leak isn’t going to be declined because of an exhaust mod.
