etorque stalling
Dave3d
I'm still deciding what truck to buy. I like the ram 1500 and how it drives and the comfort of it, but reading about the issues has me scared to pull the trigger. Has the stalling issues been linked to faulty battery from facrory.....or do I just get the hemi with no etorque
thanks for the reply. seems like its been awhile for not having a fix
Well, if it was a concern, I'd just get it without the eTorque. But there are lots of eTorque trucks that haven't had that issue or they would have a fix. Probably about a 1% chance if that.
I have the e-torque, haven't had an issue with mine. There is a recall to update programming, but I'm not going to waste my time at the dealer for a problem that currently doesn't exist. You didn't say if you were looking at new or used - If you aren't looking to order a new one, you can still find Hemi non-e's on dealer lots
I havent had an issue with eTorque.
Remember that these forums are a place where you see people noting problems, the people without problems dont come on and post threads "I have no problems, all is good"
A lot less then 1% if you think about it. That would be 1 truck in every 100 sold has that problem...
I have an eTorque and have had the issue but only on cold stops - Truck not at temp and a stop sign. I have been doing some of my own testing on this and found it to be more
of a temperature issue with the transmission. If I leave the house after about a 5 minute warmup. When I get to the stop sign 3/10 of a mile away and stop as normal it will stutter.
But if I coast up to it an stop really slow it has no issue. But everything else on the truck is great. There is a TSB you can have put on it if you can find dealer that doesn't tell "NO".
I'm thinking of paying to have it put on. Also, the eT is getting me 16mpg around town - lots of stop and go so the auto start/stop payoffs.
Have you check your trans fluid?
I found mine was over filled from the factory a decent amount.
After letting it drain out (from the fill plug) it seems to run a bit better for me.
There are a few updates you can have done on the eTorque system free of charge at the dealership. Even my 2022 had 1 or 2 updates to be applied.
I have a 2022 G/T with e torque that had a bad stalling and bucking issue. It happened several times from the time of purchase until recently. They reflashed the PCM with updated firmware for the stalling issue and I haven’t had a problem in the past 1K miles. I now have 5400 miles on it.
There are fixes for the stalling, it has been reported many times. There are different updates depending on the situation. PCM, TCM,and BPCM all have updates for small concerns
How overfilled was it?
Thanks for all the input. I am looking at used, many that are not on a ram dealership. What type of warranty should I ask for??
Whatever you are happy with and can actually get
A good build car\truck shouldn't need a warranty.
I would avoid 2019s (first year of 5th gen model) and get 2020+ if possible.
Do you know which updates you had done on your 2022....mine stalled and seems to run jerky but the dealership did nothing saying it is not eligible for any updates.
Thanks!
2 TSB's were recently released for 2022 DT for improved shifting and ESS restarts.
Z49 Hybrid Control Processor HCP update
Thanks! It seems all the updates are for Hemi etorques and not V6. I really have no clue about the difference when it comes to the electronics. If it states Hemi, anyone know if these updates would work for the V6's. Frustrating that after 2 other Ram trucks with only minimal issues, I now have a brand new one that I feel like I am going to crash at any moment.
Thank you, these are also stating for the HEMIs but I have a V6. I am supposed to be driving the service manager around Friday so he can experience what I experience (insert eye roll) but of course I am sure they will say it is nothing and I highly doubt it will stall in the 5 minutes he is in the truck with me but I am going to show him these two TSBs. I am sure he will say it is not valid for my V6 engine and I cannot seem to find anyone with a V6 that has had updates to their trucks.
