Darksteel165
Mine doesn't even have that much at idle, let alone while eTorque is enraged the engine is not idle (goes to 0)They have 50 psi of lubrication at idle, at least mine does
Yeah, I'm aware that I omitted the word cold from my previous post. Definitely an oversight. But I'm not convinced that more wear doesn't occur at warm start than if the engine were kept running. Again, as mentioned in my previous post, that's purely my opinion. But until I see data on wear in an engine that sees lots of stop/start operations versus an engine that doesn't, I'm sticking with my gut feeling.Most engine wear occurs at COLD startups, not hot/warm
STARTUP WEAR IN AUTOMOBILE ENGINES
Studies in laboratory engines equipped with radioactive piston rings show that wear is highest during a cold startup. Corrosion by condensed combustion products is responsible.Engine operating variables and additives in fuels and motor oils influence corrosion and, therefore, startup wear. Long shutwww.sae.org
Not sure why you posted that link. It lost me with the first sentence...
"Studies in laboratory engines equipped with radioactive piston rings show that wear is highest during a cold startup. Corrosion by condensed combustion products is responsible."
I'm not a scientist of any sort, but exactly how do "laboratory engines equipped with radioactive piston rings" correlate to real-world engines?
Haha, thanks for twisting my words. That's not what I said and you know it.One of the premises between warm/hot vs cold start is that a warm/hot engine was previously running and has a substantial amount of oil cling on all the parts vs an engine that's sat long enough to get cold and that same oil having dripped off. Radioactive rings just allows for more precise measurement of loss of material.
I'd think a running idling engine is wearing more than an engine not running but thats me
Restarting the engine over and over, not good, and most of all.... it does nothing. Was just for tree huggers in power. It damn sure isn't for fuel milage because I've yet to find anyone who tells me "it makes a big difference." It's so minimal you barley if ever even notice it.Honest question for those that either permanently or each time you get in your truck, disable stop/start.
And OP, sorry for derailing a little here.
Why?
Is it because you don’t trust it? Is it because you drive in a lot of stop/go traffic and find it annoying? Is it because…you’re old school, annoying, don’t see the need/feel the need?
For me, I shut it off in traffic jams and the drive through. Annoying.
On my wife’s old Cherokee, it was not smooth, very jerky…and I always shut it off.
However, in this truck, aside from those times listed above, it truly doesn’t bother me. It’s smooth, reliable thus far…
Just curious as to why some feel the need to shut it off and disable.
It sounds like you regret getting the e-torq. As with my non e-torq, I always hit gear limiter so the eco mode does not engage. Just my opinion, neither is helps enough for the minimal fuel savings.So besides buying a bypass harness and or turning it off.... to date no one has figured out how to just completely disconnect this usless feature?
Yes I do. If I were to do it again i would have went with a 22, just missed the deadline to build and there were none with every package I wanted.It sounds like you regret getting the e-torq. As with my non e-torq, I always hit gear limiter so the eco mode does not engage. Just my opinion, neither is helps enough for the minimal fuel savings.
