Did you ever get a resolution? My truck has been doing the same thing since late December. Now 2 batteries later, $700+ in diagnostics & new BCM, battery still dies overnight. Truck back at dealer now….9 days…they can’t find source of parasitic drain.my 2019 5.7 L ram 1500
Electric Brake Vacuum Pump keeps cyling on and off and it killed my battery. is this an issue for anyone else? Is this a warranty issue?
What DTC`s did it store? If any, besides maybe "battery voltage too low/out of range"Did you ever get a resolution? My truck has been doing the same thing since late December. Now 2 batteries later, $700+ in diagnostics & new BCM, battery still dies overnight. Truck back at dealer now….9 days…they can’t find source of parasitic drain.
C212A-16What DTC`s did it store? If any, besides maybe "battery voltage too low/out of range"
Thanks for the reply. Truck is still at dealer. I’m supposed to get it back Friday. They “think” they have it fixed, but want to leave it out tonight and re-test tomorrow (and I get get a ride back to dealer till Friday after we missed today).C212A-16.
9 modules and 2 sensors can throw that "system voltage- circuit voltage below threshold.
U0403-00.
DASM, PTS/PAM, ABS and TCM "implausible data from transfer case"
U0418.
PCM. "implausible data received from brake system control module"
U1440.
PCM. "implausible transfer case ratio high received"
P1DF3-00. Transmission control module-ECU not initialized.
All these sound like random DTC`s caused by your battery being dragged down.
It probably would not hurt to check the left fender G921/922/933 ground for integrity.
Cleaning this took care of my parasitic drain killing the battery overnight issue.
Grounds are extremely important with electronics. I'm old with a bad memory, but I do recall early DT's having an issue with the electric steering. My ex's current husband was an engineer who designed the fasteners. He said the problem ended up being somebody high up, had changed one bolt to a similar bolt trying to save money, only having to stock one type. I don't know what was special about the bolt, but it made a difference, and they had to recall thousands of trucks, to change that bolt.C212A-16.
U0403-00.
U0418.
U1440.
Went to dealer…truck wouldn’t turn over…left it again…tech who worked on it is off today. Battery completely run down, likely my 2nd new battery is shot too.Grounds are extremely important with electronics. I'm old with a bad memory, but I do recall early DT's having an issue with the electric steering. My ex's current husband was an engineer who designed the fasteners. He said the problem ended up being somebody high up, had changed one bolt to a similar bolt trying to save money, only having to stock one type. I don't know what was special about the bolt, but it made a difference, and they had to recall thousands of trucks, to change that bolt.
I just started having this issue 2 days ago. When I turn the truck off the electric vacuum pump continues to cycle and get extremely hot from running nonstop until the battery dies.I have the same problem, did you get a solution?
I have the same issue now on my 2019 Rebel Did you find out how to fix the issue?my 2019 5.7 L ram 1500
