Dropped oil filler cap into engine bay, any ideas?
JakeHagg25
So the other day I was replacing my fuel injectors (already had two fail on me at 40k miles so I decided to do the rest) and in the process I had to take the oil fill cap off. Unfortunately for me when I took it off it fell and I didn't get a chance to see where it fell into. It never hit the ground and I quite literally spent an hour looking to no avail.
So now I turn to you all, does anyone have any suggestions for where it may have gotten stuck? I went so far as driving my truck up and down the driveway to maybe knock it loose but no dice.
Aseras
Get a flashlight and start looking. Record video on your phone and wave it around all over slow and watch the video on a larger monitor and see if you can find it.
I found 2 oil caps lost in our work truck engine bay when I had to replace the AC compressor. If they don't fall out they stay put.
Aseras
If just get a replacement and leave the other one. It’ll turn up or fall out on the road. I had a similar thing happen to me with a 15mm socket. I never saw it again.
At least with a socket you can go magnet fishing.
bskubon
I’d worry it would hit like the fan belt and cause an issue
ben b
SF Bay Area
Do you think an endoscope would help? Amazon shows multiple at less than $100. Might come in handy for other projects too.
Aseras
Turn on your flash on the phone and just take video slowly and go around it. Tape it to a yard stick if you need to get in deep. Watch it on a pc and you'll find it if it is in there. I have an endoscope and it excels at getting a view in tiny things ( like inside body parts, pipes and tires ). It's not a good camera. any phone will blow them all away in clarity, if the phone can fit.
