DRL Power Source Splice or Harness Splitter
wildh24
I'm looking to add some accent lighting to the front end grill. Ideally it would just run with the DRL LED strips in the head light. This is a low wattage need so I'm considering tapping into the wiring.
Thoughts? Or does anyone know if there is a simple splitter harness to accomplish this?
Haven't seen a splitter harness yet but I spliced into the driver side high beam wire (white/green) for a light bar install I did a few months ago and haven't had any issues yet, although I only had a relay tapped into it which draws a fraction of an amp so there's no real way for the computer to tell if it's drawing to much power. If you're just hooking up the lights directly to the DRL the computer might not like that and think something's wrong if i'ts drawing more power than the computer allows in that circuit.
Didn’t want to repost so I thought maybe someone came up with a solution for this. I have some DRL’s I’d like to come on with the headlight accents. Anyone know which wire or circuit lights these? I checked the wiring diagram post and couldn’t find it. TIA
