I know this issue has been brought up before, but at just over two years into owning my truck I noticed I have a water leak in the front drivers side of my truck.
I’ve never had issues with wet carpet, and have checked it many times over the last two years. Just the other day I was cleaning my truck and decided to remove the sill panel to do some spring cleaning and I noticed it was wet. After lifting the carpet I noticed the under pad and sound deadening that is glued to the floor was soaking wet.
I thought maybe I water got into there off my rubber mats, so I left the carpet lifted up overnight for a couple of nights to dry. Today it rained again, upon inspection I can see fresh water trickling down the seam from up under the drivers side kick panel somewhere.
Back to the dealer she goes! Glad I bought an extended warranty, because this is getting ridiculous.
You can remove the sill panel easily by lifting up at the rear of it and working your way to the front where two more clips hold it in, just pull back and it comes right off. You can then just lift up on the carpet but the black clips that hold it down and lift the carpet to check it out, I’ve never had wet carpet so I thought I was fine, I guess not.
