Driver's side DRL - ring light fading
TCRAM
First time poster. I have a 2019 2500 and the drivers side DRL - ring light is fading on the top (hopefully you'll be able to tell in the attached pictures). Is there a way to fix this, or do I need to replace the whole headlight? TIA
kapinallinen2
5thGenRams Supporter
Southern Maryland.
Pretty sure you need to replace the whole assembly, unless you can source the needed components and can bake the housing apart.
You might get better answers at the HD section.
Homepage - HD Rams
