Ddecarlo314
- Jan 7, 2021
So I am having an issue with my drivers front door. It will not turn the radio off when I open it after the ignition is turned off. It also does not unlock all the doors even though the setting in the radio is checked. Also the interior dome lights do not come on when the door is open. It also seems that a sensor failed in the door closed mode. Does anyone know if there is a sensor for the drivers front door? Or is it controlled through the BCM?
thanks
Dan
thanks
Dan
