Hi everybody quick question as you know with the air suspension once you go over a certain speed it takes you from off-road 2 into normal mode. I want to know if it is possible to lock it into off-road 2 so that no matter what speed you went it stayed in off-road 2. I’m not asking if you think I should do it or if it’s the right thing to do I wanna know if it’s possible and if somewhere in the settings I can do something so that when I go over the certain speed it doesn’t lower the truck like it usually does but rather just stays in off-road 2, thank you. 2019 RAM 1500 Limited.
