PM-Performance
- Dec 20, 2020
It is apparent you suffer from reading comprehension.So adding longtubes headers doesn't "uncork" any additional flow? Got it
I said you do not need to tune for exhaust work and that exhaust has nothing to do with parameters that get modified in a tune.
All free flowing exhaust work uncorks power. The point is that exhaust work has nothing to do with tuning and is not needed nor has any relevance to each other.
You CAN tune a stock vehicle if you like, just like you CAN tune a vehicle with headers. The result will be the same regardless that you tune spark/fuel/trans shift points. None of these values change based on the amount of gasses you expel.
**** next you are going to tell me you lost power when your cel is on from removing your cats.
