Ramhighflyer
- Nov 15, 2020
So I have a question… would like to cavity wax the doors on my 21 Laramie….. at least the bottom portion of it….. looks like there is a weather strip on the bottom of the door that is fastened with the xmas tree push pins…. Would like to remove this strip, use the push pin holes to access the door cavity and not have to remove the whole door panel… will probably damage some of these pushpins removing them.
Does anyone have a part number, if any , for these push Pins? the parts diagram does not show them individually, but it looks like they are used all over for the various seals …..if not i might see if I can remove one, measure it up and see if I can find some generic…
Thanks
Pete
Thanks
Pete
