I have a rattle near the drivers side door somewhere when going over rough roads or bumps. Almost like something is loose inside the door. Can someone please help me! Thanks.
Check your exterior molding on the door (not the body), particularly at the front of the door near the bottom. Make sure all the push rivets are fully pushed in. Another possibility is sway bar end links, I believe there is a TSB for certain build dates. If you narrow it down to the door you may have to take off the interior panel to correct the issue
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
