Door panel screw help
Bubandjam
I am having problems removing one of the 10mm screws, i got the door handle one out and one of the lowers, the other one is just spinning and wont release so i can get door panel off.....anyone have any fixes to try?
If it’s spinning it might not even be threaded and a good yank might do the trick once the other screws are removed. You can also try grabbing the head of the screw with pliers and twist/pull at the same time
